fout in schetch van beginner
12 berichten
Arduino:1.8.15 Hourly Build 2021/08/23 12:33 (Windows 10), Board:"ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 115200, None"
17relay_zelf_made:57:17: error: 'buildpage' was not declared in this scope
buildpage();
C:\Users\Gebruiker\Documents\Arduino\17relay_zelf_made\17relay_zelf_made.ino: In function 'void setup()':
17relay_zelf_made:59:5: error: 'serial' was not declared in this scope
serial.println("http server started");
17relay_zelf_made:61:12: error: expected unqualified-id before '(' token
server.("/led1on", []()
C:\Users\Gebruiker\Documents\Arduino\17relay_zelf_made\17relay_zelf_made.ino: In lambda function:
17relay_zelf_made:63:17: error: 'buildpage' was not declared in this scope
buildpage();
17relay_zelf_made:68:12: error: expected unqualified-id before '(' token
server.("/led1off", []()
17relay_zelf_made:71:17: error: 'buildpage' was not declared in this scope
buildpage();
17relay_zelf_made:76:17: error: 'buildpage' was not declared in this scope
buildpage();
17relay_zelf_made:82:7: error: 'build' was not declared in this scope
build page();
17relay_zelf_made:88:16: error: 'buildpage' was not declared in this scope
buildpage();
17relay_zelf_made:93:31: error: expected '{' before '}' token
server.on("/Refresh", []()}
17relay_zelf_made:93:31: error: expected ')' before '}' token
17relay_zelf_made:95:17: error: 'buildpage' was not declared in this scope
buildpage();
17relay_zelf_made:97:6: error: expected primary-expression before ')' token
17relay_zelf_made:103:3: error: a function-definition is not allowed here before '{' token
17relay_zelf_made:114:7: error: 'webpage' was not declared in this scope
webpage += "<p>Led No 1 <a href=\ `Led1On\`><button";
17relay_zelf_made:115:7: error: expected primary-expression before 'class'
class = "button~>ON</button>";
17relay_zelf_made:117:7: error: expected primary-expression before 'class'
class = "button`>OFF</button></a></p>";
17relay_zelf_made:119:7: error: expected primary-expression before 'class'
17relay_zelf_made:121:7: error: expected primary-expression before 'class'
17relay_zelf_made:123:7: error: expected primary-expression before 'class'
class = "button'Refresh</button>";
17relay_zelf_made:126:5: error: expected '}' at end of input
Bibliotheek WiFi op versie 1.0 in map: C:\Users\Gebruiker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi wordt gebruikt
Bibliotheek WebServer op versie 1.0 in map: C:\Users\Gebruiker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WebServer wordt gebruikt
Bibliotheek FS op versie 1.0 in map: C:\Users\Gebruiker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\FS wordt gebruikt
exit status 1
Hier gaat van alles fout maar ik kom er niet meer uit
ben een beginner in het begin
mischien zit er een simpel foutje in alleen ik kom er niet achter
wie kan mijn verder helpen?
b v d
buildpage();
buildpage();
buildpage();
buildpage();
build page();
buildpage();
buildpage();
exit status 1
b v d
Re: fout in schetch van beginner
dit is hetzelfde als ik de wegenwacht bel met de mededeling dat er wat rammelt.
de eerste kan ik wel vinden serial moet met een grote S
de rest is gokken zonder programma erbij. als je gaat checken zie je een lange lijst met fouten, ga naar de eerste en probeer die op te lossen. Vaak een typefout of een haakje
Mijn advies sluit aan op wat shooter al schreef. Om je een beetje op weg te helpen:
(bijna) elke regel moet afgesloten worden met een puntkomma
Wat echt bij elkaar hoort begint met een accolade en moet ook eindigen met een accolade.
Als je op CTRL + T drukt zet de ide zelf de code met inspringing zoals de ide dat begrijpt. Hiermee zie je vaak snel waar ergens een puntkomma is vergeten, een haakje of een accolade teveel of te weinig staat. Let ook op de kleur van de code. Afwijkende kleur betekent vaak dat een statement niet door de compiler wordt begrepen.
serial.print(); en Serial.print(); zijn voor mensen wel hetzelfde maar wel of geen hoofdletter maakt dat de compiler niet begrijpt wat jij bedoelt.
hallo
fijn dat jullie antwoord geven maar ik leer veel door er gewoon aan te beginnen en dan van de fouten te leren
maar soms kom je hier niet verder mee
dan maar vragen........
hier is de hele programma waar het om gaat
#include <ETH.h>
#include <WiFi.h>
#include <WiFiAP.h>
#include <WiFiClient.h>
#include <WiFiGeneric.h>
#include <WiFiMulti.h>
#include <WiFiScan.h>
#include <WiFiServer.h>
#include <WiFiSTA.h>
#include <WiFiType.h>
#include <WiFiUdp.h>
#include <WebServer.h>
// dit is voor esp32 om met de tablet iets aan te sturen
WebServer server(80);
int ledpin = 32;
int ledpin2 = 33;
#define RELAY1 23
#define RELAY2 22
#define RELAY3 21
#define RELAY4 19
const char* ssid = "xxxxxxx";
const char* password = "xxxxxxxx";
String webPage = "";
Serial.begin(115200);
WiFi.begin(ssid, password);
Serial.println("");
while (WiFi.status() != WL_CONNECTED)
delay (500);
Serial.print(".");
Serial.println("");
Serial.print("Conneted to ");
Serial.println(ssid);
Serial.print("ip adress: ");
pinMode (ledpin, OUTPUT);
pinMode (ledpin2, OUTPUT);
server.begin();
server.on("/", []()
buildpage();
Serial.println("http server started");
buildpage();
digitalWrite(ledpin, HIGH);
buildpage();
server.on("/led1off", []()
buildpage();
digitalWrite(ledpin, LOW);
server.on("/led2on", []()
build page();
digitalWrite(ledpin2, HIGH);
buildpage();
digitalWrite(ledpin2, LOW);
buildpage();
server.begin();
Serial.println("HTTP server starded");
server.handleClient();
void BUILDPAGE();
webPage = "";
webPage += "<!DOCTYPE html>";
webPage += "<html><body>";
webPage += "esp web control";
webPage += "br>";
webPage += "lamp aan";
webpage += "</a> <a href=\`Led1OFF\`><button";
webpage += "<p>Led No 2 <a href=\ `Led2On\`><button";
webpage += "</a> <a href=\`Led2OFF\`><button";
webpage += "<p>CLick to refresh <ahref=\'Refresh\'><button";
webPage += "</a></p>";
server.send (200, "text/html", webPage);
#include <ETH.h>
#include <WiFi.h>
#include <WiFiAP.h>
int ledpin = 32;
int ledpin2 = 33;
#define RELAY1 23
#define RELAY2 22
#define RELAY3 21
#define RELAY4 19
Serial.println("");
delay (500);
Serial.print(".");
Serial.println("");
server.begin();
server.on("/", []()
buildpage();
buildpage();
buildpage();
buildpage();
build page();
buildpage();
buildpage();
server.begin();
void BUILDPAGE();
webPage = "";
webPage += "br>";
hallo
ben een tijdje bezig geweest
en er heel veel fouten uit gehaald
nu heb ik hem zo ver dat ik op mijn telefoon de knoppen kan zien en bedienen
maar als ik op een knop druk krijg ik een melding not found on, not fond off enz.
dit is nog een dingetje....
wie weet daar een oplossing voor?
b v d
b v d
ik denk dat in de server er iets mis gaat met server.on en off.
Serial.println("");
} // Hier eindigt jouw setup door de sluitende accolade
{ // Dus vanaf hier tot een tiental regels later loopt het fout door verkeerd gebruik van ( , { , }
delay (500);
Serial.print(".");
Serial.println("");
server.begin();
server.on("/", []()
buildpage();
buildpage();
buildpage();
buildpage();
build page();
buildpage();
buildpage();
server.begin();
} // Tot hier dus ,ik denk dat het de bedoeling is hier het eind van de void setup aan te geven
Het is misschien makkelijker om link te geven waar je de code vandaan hebt.
Die foutjes gebeuren meestal door Knippen, copieren en plakken.
Je bent goed op weg.
Serial.println("");
delay (500);
Serial.print(".");
Serial.println("");
server.begin();
server.on("/", []()
buildpage();
buildpage();
buildpage();
buildpage();
build page();
buildpage();
buildpage();
server.begin();
Je bent, zoals Gij Kieken schreef, goed op weg.
Wat mij nog opvalt is dat je onder anderen op regel 58 de funktie buildpage() aanroept maar de compiler zal die niet vinden. De funktie BUILDPAGE() is er wel en lijkt erop maar de compiler ziet dat anders.
ben ik weer
dit is een voorbeeld die uit een boek is overgetypt
maar als je dat doet sluipen er erg veel foutjes in ook omdat ik nog niet helemaal weet waar het voor dient
ik krijg hem nu weg geschreven op het bordje zie ook de knoppen maar als ik ze aanraak is het: not fond:/led1on ,off enz
ik vul in de brouwser alleen het i p adress in wat op de seriële monitor staat
B v D
#include <ETH.h>
#include <WiFi.h>
#include <WiFiAP.h>
int ledpin = 32;
int ledpin2 = 33;
const char* ssid = "xxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxx";
Serial.println("");
delay (500);
Serial.print(".");
Serial.println("");
server.on("/", []()
buildpage();
server.on("/led1on", []()
buildpage();
buildpage();
buildpage();
buildpage();
buildpage();
server.on("/Refresh",[]()
buildpage();
server.begin();
void buildpage()
webPage = "";
webPage += "br>";
webPage += "lamp aan en uit";
webPage += "<p>Led No.1<a href=\'Led1On\'><button class ='button'>ON</button>";
webPage += "</a> <a href=\'Led1OFF\'><button class ='button'>OFF</button></a></p>";
webPage += "<p>Led No.2<a href=\'Led2On\'><button class ='button'>ON</button>";
webPage += "</a> <a href=\'Led2OFF\'><button class ='button'>OFF</button></a></p>";
webPage += "<p>CLick to refresh<a href =\'Refresh\'><button class='button'>Refresh</button>";
B v D
#include <ETH.h>
#include <WiFi.h>
#include <WiFiAP.h>
int ledpin = 32;
int ledpin2 = 33;
Serial.println("");
delay (500);
Serial.print(".");
Serial.println("");
server.on("/", []()
buildpage();
buildpage();
buildpage();
buildpage();
buildpage();
buildpage();
buildpage();
server.begin();
void buildpage()
webPage = "";
webPage += "br>";
Ik heb zelf geen enkele ervaring met iets op een server opzoeken enz. maar vraag me af of de pagina die je bezoekt wel de nodige info heeft.
Hier is een korte tutorial met uitleg. https://electropeak.com/learn/create-a-web-server-w-esp32/
12 berichten
