VS1053 sturing hangt vast in while lus
SPI versturen werkt, maar de code blijft hangen in de while (playingMusic && Ready()) {feedBuffer();} lus.
Enig idee waarom het hier blijft hangen?
//#include <Adafruit_VS1053.h>
#include <SPI.h>
#include <SD.h>
#define VS1053_FILEPLAYER_TIMER0_INT 255 // allows useInterrupt to accept pins 0 to 254
#define VS1053_FILEPLAYER_PIN_INT 5
#define VS1053_SCI_READ 0x03
#define VS1053_SCI_WRITE 0x02
#define VS1053_REG_MODE 0x00
#define VS1053_REG_STATUS 0x01
#define VS1053_REG_BASS 0x02
#define VS1053_REG_CLOCKF 0x03
#define VS1053_REG_DECODETIME 0x04
#define VS1053_REG_AUDATA 0x05
#define VS1053_REG_WRAM 0x06
#define VS1053_REG_WRAMADDR 0x07
#define VS1053_REG_HDAT0 0x08
#define VS1053_REG_HDAT1 0x09
#define VS1053_REG_VOLUME 0x0B
#define VS1053_GPIO_DDR 0xC017
#define VS1053_GPIO_IDATA 0xC018
#define VS1053_GPIO_ODATA 0xC019
#define VS1053_INT_ENABLE 0xC01A
#define VS1053_MODE_SM_DIFF 0x0001
#define VS1053_MODE_SM_LAYER12 0x0002
#define VS1053_MODE_SM_RESET 0x0004
#define VS1053_MODE_SM_CANCEL 0x0008
#define VS1053_MODE_SM_EARSPKLO 0x0010
#define VS1053_MODE_SM_TESTS 0x0020
#define VS1053_MODE_SM_STREAM 0x0040
#define VS1053_MODE_SM_SDINEW 0x0800
#define VS1053_MODE_SM_ADPCM 0x1000
#define VS1053_MODE_SM_LINE1 0x4000
#define VS1053_MODE_SM_CLKRANGE 0x8000
#define VS1053_SCI_AIADDR 0x0A
#define VS1053_SCI_AICTRL0 0x0C
#define VS1053_SCI_AICTRL1 0x0D
#define VS1053_SCI_AICTRL2 0x0E
#define VS1053_SCI_AICTRL3 0x0F
#define VS1053_DATABUFFERLEN 32
//MP3
#define MP3_CS 7 //Chip select
#define MP3_DCS 6 //Data select
#define MP3_DREQ 3 //Data Request
//COMMON
#define SD_CS 4 //SD select
#define RST -1 //Reset*/
typedef volatile uint8_t RwReg;
typedef uint8_t PortMask;
typedef volatile RwReg PortReg;
volatile boolean BufferLock=false;
static volatile PortReg *clkportreg, *misoportreg, *mosiportreg;
static PortMask clkpin, misopin, mosipin;
volatile boolean playingMusic;
boolean Play (const char *trackname);
boolean Ready(void);
void SPI_write(uint8_t addr, uint16_t data);
void spiwrite(uint8_t c);
void spiwrite(uint8_t *c, uint16_t num);
void feedBuffer(void);
void feedBuffer_noLock(void);
void playData(uint8_t *buf, uint8_t buffsiz);
uint8_t mp3buffer[32];
File currentTrack;
delay(200);
pinMode (MP3_CS, OUTPUT);
pinMode (MP3_DCS, OUTPUT);
pinMode (MP3_DREQ, INPUT);
pinMode (SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH);
Serial.println("begin");
SPI.begin();
Play("/track001.mp3");
while(playingMusic){}
Serial.println("after play");
Serial.println("loop");
delay(2000);
boolean Play (const char *trackname){
SPI_write(VS1053_REG_MODE, VS1053_MODE_SM_LINE1 | VS1053_MODE_SM_SDINEW); // reset playback
Serial.println("spi1");
SPI_write(VS1053_REG_WRAMADDR, 0x1e29); // resync
Serial.println("spi2");
SPI_write(VS1053_REG_WRAM, 0);
Serial.println("spi3");
currentTrack = SD.open(trackname);
noInterrupts();
Serial.println("no interrupt");
SPI_write(VS1053_REG_DECODETIME, 0x00);
Serial.println("spi 4+5");
playingMusic = true;
while (!Ready()){}
Serial.println("!ready");
Serial.println("feedbuffer done");
interrupts();
return true;
boolean Ready(void){
Serial.println("DREQ");
return digitalRead(MP3_DREQ);
void SPI_write(uint8_t addr, uint16_t data){
Serial.println("send");
digitalWrite(MP3_CS, LOW);
spiwrite(VS1053_SCI_WRITE); //0x02
spiwrite(addr);
spiwrite(data >> 8);
spiwrite(data & 0xFF);
digitalWrite(MP3_CS, HIGH);
Serial.println("spi done1");
void spiwrite(uint8_t c){
uint8_t x __attribute__ ((aligned (32))) = c;
spiwrite(&x, 1);
Serial.println("spi done2");
void spiwrite(uint8_t *c, uint16_t num){
clkportreg = portOutputRegister(digitalPinToPort(13));
clkpin = digitalPinToBitMask(13);
misoportreg = portInputRegister(digitalPinToPort(12));
misopin = digitalPinToBitMask(12);
mosiportreg = portOutputRegister(digitalPinToPort(11));
mosipin = digitalPinToBitMask(11);
while (num--) {
for (int8_t i=7; i>=0; i--) {
*clkportreg &= ~clkpin;
if (c[0] & (1<<i)) {
*mosiportreg |= mosipin;
*mosiportreg &= ~mosipin;
*clkportreg |= clkpin;
*clkportreg &= ~clkpin; // Make sure clock ends low
c++;
Serial.println("spi done3");
void feedBuffer (void){
Serial.println("function feedbuffer");
noInterrupts();
if (BufferLock) {
interrupts();
return;
BufferLock = true;
interrupts();
feedBuffer_noLock();
BufferLock = false;
void feedBuffer_noLock(void){
Serial.println("function no_lock");
if ((! playingMusic)||(! currentTrack)||(! Ready())){
return; // paused or stopped
// Feed the hungry buffer! :)
while (Ready()) {
// Read some audio data from the SD card file
int bytesread = currentTrack.read(mp3buffer, VS1053_DATABUFFERLEN);
if (bytesread == 0) {
// must be at the end of the file, wrap it up!
playingMusic = false;
currentTrack.close();
playData(mp3buffer, bytesread);
Serial.println("no_lock done");
void playData(uint8_t *buf, uint8_t buffsiz) {
digitalWrite(MP3_DCS, LOW);
spiwrite(buf, buffsiz);
digitalWrite(MP3_DCS, HIGH);
Serial.println("play data done");
Re: VS1053 sturing hangt vast in while lus
die playing music wordt niet uitgezet.
