Loopkrant
Loopkrant
Wie helpt mij de ino code aan te passen om de tekst via smartphone (bluetooth) te kunnen wijzigen?
Ik gebruik de bluetooth module HC-05 of HC-06.
De loopkrant is aangestuurd met teensy 3.2 en een rgb matrix 16x128 leds.
* Modified example copied from FastLED 3.0 Branch - originally written by Daniel Garcia
* This example shows how to use some of FastLED's functions with the SmartMatrix Library
* using the SmartMatrix buffers directly instead of FastLED's buffers.
* FastLED's dithering and color balance features can't be used this way, but SmartMatrix can draw in
* 36-bit color and so dithering may not provide much advantage. There's no one 'right' way to use these two
* libraries together, try this example and FastLED_Controller and figure out what is 'right' for you
* This example requires FastLED 3.0 or higher. If you are having trouble compiling, see
* the troubleshooting instructions here:
* https://github.com/pixelmatix/SmartMatrix/#external-libraries
#include <SmartLEDShieldV4.h>
#include <SmartMatrix3.h>
#include <FastLED.h>
#define COLOR_DEPTH 24 // This sketch and FastLED uses type `rgb24` directly, COLOR_DEPTH must be 24
const uint8_t kMatrixWidth = 128; // known working: 32, 64, 96, 128
const uint8_t kMatrixHeight = 16; // known working: 16, 32, 48, 64
const uint8_t kRefreshDepth = 48; // known working: 24, 36, 48
const uint8_t kDmaBufferRows = 4; // known working: 2-4, use 2 to save memory, more to keep from dropping frames and automatically lowering refresh rate
const uint8_t kPanelType = SMARTMATRIX_HUB75_16ROW_MOD8SCAN; // use SMARTMATRIX_HUB75_16ROW_MOD8SCAN for common 16x32 panels use SMARTMATRIX_HUB75_32ROW_MOD16SCAN for32x64
const uint8_t kMatrixOptions = (SMARTMATRIX_OPTIONS_NONE); // see http://docs.pixelmatix.com/SmartMatrix for options
const uint8_t kBackgroundLayerOptions = (SM_BACKGROUND_OPTIONS_NONE);
const uint8_t kScrollingLayerOptions = (SM_SCROLLING_OPTIONS_NONE);
SMARTMATRIX_ALLOCATE_BUFFERS(matrix, kMatrixWidth, kMatrixHeight, kRefreshDepth, kDmaBufferRows, kPanelType, kMatrixOptions);
SMARTMATRIX_ALLOCATE_BACKGROUND_LAYER(backgroundLayer, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kBackgroundLayerOptions);
SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(scrollingLayer1, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
// The 32bit version of our coordinates
static uint16_t x;
static uint16_t y;
static uint16_t z;
// We're using the x/y dimensions to map to the x/y pixels on the matrix. We'll
// use the z-axis for "time". speed determines how fast time moves forward. Try
// 1 for a very slow moving effect, or 60 for something that ends up looking like
// water.
// uint16_t speed = 1; // almost looks like a painting, moves very slowly
uint16_t speed = 60; // a nice starting speed, mixes well with a scale of 100
// uint16_t speed = 33;
// uint16_t speed = 100; // wicked fast!
// Scale determines how far apart the pixels in our noise matrix are. Try
// changing these values around to see how it affects the motion of the display. The
// higher the value of scale, the more "zoomed out" the noise iwll be. A value
// of 1 will be so zoomed in, you'll mostly see solid colors.
// uint16_t scale = 1; // mostly just solid colors
// uint16_t scale = 4011; // very zoomed out and shimmery
uint16_t scale = 45;
// This is the array that we keep our computed noise values in
uint8_t noise[kMatrixWidth][kMatrixHeight];
delay(6000);
matrix.addLayer(&backgroundLayer);
matrix.addLayer(&scrollingLayer1);
matrix.begin();
backgroundLayer.setBrightness(96);
// Initialize our coordinates to some random values
x = random16();
y = random16();
z = random16();
// Show off smart matrix scrolling text
scrollingLayer1.setMode(wrapForward);
scrollingLayer1.setColor({0xff, 0xff, 0xff});
scrollingLayer1.setSpeed(40);
scrollingLayer1.setFont(font6x10);
scrollingLayer1.start("Hard Rock Music ***** We Love It", -1);
scrollingLayer1.setOffsetFromTop((kMatrixHeight/2) - 5);
// Fill the x/y array of 8-bit noise values using the inoise8 function.
void fillnoise8() {
for(int i = 0; i < kMatrixWidth; i++) {
int ioffset = scale * i;
for(int j = 0; j < kMatrixHeight; j++) {
int joffset = scale * j;
noise[i][j] = inoise8(x + ioffset,y + joffset,z);
z += speed;
static uint8_t circlex = 0;
static uint8_t circley = 0;
// if sketch uses swapBuffers(false), wait to get a new backBuffer() pointer after the swap is done:
// while(backgroundLayer.isSwapPending());
rgb24 *buffer = backgroundLayer.backBuffer();
static uint8_t ihue=0;
fillnoise8();
// We use the value at the (i,j) coordinate in the noise
// array for our brightness, and the flipped value from (j,i)
// for our pixel's hue.
buffer[kMatrixWidth*j + i] = CRGB(CHSV(noise[j][i],255,noise[i][j]));
// You can also explore other ways to constrain the hue used, like below
//buffer[kMatrixHeight*j + i] = CRGB(CHSV(ihue + (noise[j][i]>>2),255,noise[i][j]));
ihue+=1;
backgroundLayer.fillCircle(circlex % kMatrixWidth,circley % kMatrixHeight,6,CRGB(CHSV(ihue+128,255,255)));
circlex += random16(2);
circley += random16(2);
// buffer is filled completely each time, use swapBuffers without buffer copy to save CPU cycles
backgroundLayer.swapBuffers(false);
//matrix.countFPS(); // print the loop() frames per second to Serial
Studio Bobo The Place to Be
Re: Loopkrant
Hallo JohnBobo, welkom op dit forum.
Er heeft nog niemand gereageerd, want wij schrijven geen code voor anderen.
Wanneer iemand een sketch heeft die nog niet werkt, dan proberen wij aan te geven waar de fout zit.
Misschien kun je zoeken naar iemand die al de Teensy 3.1 of 3.2 met Bluetooth heeft werken.
Heeft de Teensy 3.2 drie seriële poorten ? Dan kun je dus gemakkelijk nog een Bluetooth module toevoegen.
